Name: Build ISIS Query from ISIS List
Author: Charlie Weatherall
Version: 2.0
Created: 06/2003
Modified: 08/2007
Purpose: This protocol shows how one can use a previously-saved ISIS list file to retrieve records from an ISIS database. The protocol reads the list file and uses PilotScript to create an ISIS query from the IDs in the list. Then reads the ISIS database and applies the query to only retrieve those records.
Requirements: PP Server 6.1.1, Professional Client, Chemistry Collection, ISIS Base on the Pipeline Pilot server.
O/S: Windows only
Limitations: N/A
Keyword: ISIS Base list database structure molecule
Contents: Build ISIS Query from ISIS List.xml, ISISExternalList.lst
Installation:
1. Import the protocol by dragging and dropping the XML file into the PP client workspace.
2. Save the list file .lst in your Pipeline Pilot server user directory.
3. Make sure that the ISIS Reader in the protocol points to the valid installation of ISIS Base on your PP server and uses the sample database LOCALMX.DB.
4. Run the protocol and use CORP_ID at the prompt. You should see a series of 12 records being displayed.
