Hello. I am using materials studio 2023 version. I set the maximum iteration to 20000 in the geometry optimization task of the Forcite module, but the iteration continues to end at 2000 units. I've tried over 30 times and it keeps happening. For convergence tolerance, only max energy and max stress were set to the minimum values. Is there any way to solve this? Information about the model is attached. Also under WARNING Convergence criteria are not satisfied. I wonder why such a phrase appears, but the convergence condition is not satisfied and the optimization task ends.
Thank you so much for your help
Forcite
Task : Geometry Optimization
Version : 2023
Build date : Feb 8 2023
Host : DESKTOP-PL2D1CH
Threads : Parallel 32
Operating system : Windows
Task started : Sun Aug 20 16:51:10 2023
---- Geometry optimization parameters ----
Algorithm : Smart
Convergence tolerance:
Energy : 6e-008 kcal/mol
Stress : 1e-005 GPa
Maximum number of iterations : 20000
External pressure : 0 GPa
Motion groups rigid : NO
Optimize cell : YES
---- Energy parameters ----
Forcefield : COMPASSIII (Version 1.2)
Charges : Forcefield assigned
Electrostatic terms:
Summation method : PPPM
Accuracy : 0.001 kcal/mol
Buffer width : 2 A
van der Waals terms:
Summation method : Atom based
Truncation method : Cubic spline
Cutoff distance : 12.5 A
Spline width : 1 A
Long range correction : YES
Buffer width : 2 A
GPU is in use
---- Initial structure ----
Total enthalpy : 21209950.676264 kcal/mol
External pressure term : 0.000000 kcal/mol
Total energy : 21209950.675099 kcal/mol
Contributions to total energy (kcal/mol):
Valence energy (diag. terms) : 7201273.567
Bond : 6163060.259
Angle : 958005.734
Torsion : 24160.323
Inversion : 56047.251
Valence energy (cross terms) : 16646.764
Stretch-Stretch : 20765.931
Stretch-Bend-Stretch : -18919.439
Stretch-Torsion-Stretch : 520.998
Separated-Stretch-Stretch : 0.000
Torsion-Stretch : -10263.166
Bend-Bend : 2248.950
Torsion-Bend-Bend : 21100.765
Bend-Torsion-Bend : 1192.725
Non-bond energy : 13992030.344
van der Waals : 13946887.599
Long range correction : -825.452
Electrostatic : 45968.197
rms force : 3.131E+02 kcal/mol/A
max force : 1.499E+04 kcal/mol/A
rms stress : 4.449E+02 GPa
max stress : 6.326E+02 GPa
Cell parameters: a: 71.719124 A b: 71.719124 A c: 71.719124 A
alpha: 90.000 deg beta: 90.000 deg gamma: 90.000 deg
---- Final structure ----
Total enthalpy : 11799685.741551 kcal/mol
Total energy : 11799685.742907 kcal/mol
Valence energy (diag. terms) : 6687536.268
Bond : 5758195.994
Angle : 866238.757
Torsion : 23964.294
Inversion : 39137.222
Valence energy (cross terms) : 132976.966
Stretch-Stretch : 145709.263
Stretch-Bend-Stretch : -26740.028
Stretch-Torsion-Stretch : 725.782
Torsion-Stretch : -2761.510
Bend-Bend : 872.952
Torsion-Bend-Bend : 15600.191
Bend-Torsion-Bend : -429.684
Non-bond energy : 4979172.509
van der Waals : 4940326.931
Long range correction : -506.857
Electrostatic : 39352.435
rms force : 3.063E+02 kcal/mol/A
max force : 4.138E+03 kcal/mol/A
rms stress : 4.289E+00 GPa
max stress : 5.928E+00 GPa
Cell parameters: a: 84.495173 A b: 84.276772 A c: 84.397507 A
alpha: 90.425 deg beta: 88.565 deg gamma: 90.396 deg
Geometry optimization status
Iteration: 2110
Total enthalpy : 11799685.745287 kcal/mol
Total energy : 11799685.745181 kcal/mol
Bond : 5758195.994
Angle : 866238.757
Torsion : 23964.294
Bend-Bend : 872.952
Non-bond energy : 4979172.512
van der Waals : 4940326.934
Electrostatic : 39352.434
