I'm obligated to use Universal forcefield because I'm doing comparison study with Ta, Nb surface (this metal is not parametrized in other forcefields). The charges were assigned using QEq method (zero to 0.05 e- other options fail for charge ) . For Nb the energies are negative, but for other cases positive (can I assign these values arbitrary as negative to calculate the interaction energy or not) .
Kind regards
Kind regards
If all interactions are at their minimum and non-bond 1-3 interactions are excluded the energy for one molecule CH4 and H2O is the same when you optimize “fine” enough. It is zero. If you change a bond length or an angle the value will become positive.
The energy values which are calculated are relative to different zeros and are not comparable if the molecule changes.
