Why failed to open file error of Forcite-task
Students in my simulation class are performing MD simulations using Forcite.
One of my students got the following error message?
Does anyone have a suggestion what happened here?
Forcite
Task             : Solvation Free Energy
Version          : 7.0
Build date       : Nov 12 2013
Host             : S117450
Threads          : Parallel 8
Operating system : Windows
Task started     : Mon Jun 09 14:49:13 2014
---- Solvation free energy parameters ----
Coupling parameter start        : 0.000
Coupling parameter end          : 1.000
Coupling parameter steps        : 20
Equilibration steps             : 5000
Production steps                : 10000
Interaction to scale            : All
Free energy method              : Acceptance ratio
Convergence tolerance           : 1.000e-004 kcal/mol
---- Dynamics parameters ----
Ensemble                        : NPT
Temperature                     : 298.00 K
  Control method                : Berendsen
  Decay constant                : 0.1000000 ps
Pressure                        : 0.0001 GPa
Timestep                        : 1.00 fs
Initial velocities              : Random
Random number seed              : 1402318155
---- Energy parameters ----
Forcefield                      : COMPASSII (Version 1.0)
Charges                         : Forcefield assigned
Electrostatic terms:
  Summation method              : Ewald
  Accuracy                      : 0.001 kcal/mol
  Buffer width                  : 0.5 A
van der Waals terms:
  Summation method              : Atom based
  Truncation method             : Cubic spline
  Cutoff distance               : 12.5 A
  Spline width                  : 1 A
  Long range correction         : YES
---- Solvation free energy results ----
Ideal free energy               : -0.869 kcal/mol
Solvation free energy           : -0.869 kcal/mol
While opening C:\\PROGRA~3\\Accelrys\\MATERI~1\\7.0\\GATEWA~2\\root_default\\dsd\\jobs\\7KNHE\\AC%20met%20solute%20construct_Files\\Documents\\Status.txt - Failed to open file
Task terminated               : Mon Jun 09 19:32:53 2014
Total CPU time used by Forcite: 4:25:48 hours (15948.3s)
Regards,
Frank
