vdw in Force Field editor
I am creating a Force Field (FF) using the FF editor in Materials Studio.
However when I try to define the vdw it only allows me to set the OFF_DIAGONAL_VDW contributions.
If I open the .off file with a text editor I see that the values for the DIAGONAL_VDW.
My questions are:
the right to way to set the values is to open the .off file and assign the values to the
DIAGONAL_VDW to each atom type and the OFF_DIAGONAL_VDW are calculated based on the combination rule (e.g. geometric)?
When should I put OFF_DIAGONAL_VDW values in the FF editor interactions?
Regarding the X atom type, in Dreiding FF for instance some interactions have the X atom type.
What does this mean?
Best,
Simão
Answers 1
HP
HP 2012-06-14
Hi Simão
The van der Waals interactions that are in the DIAGONAL_VDW section of the .off file can be found on the "Types" tab of the Forcefield editor. The combination rules are accessible from the Forcefield Preferences dialog, and you can access that from the Interaction tab and the "More..." button.
The X ForcefieldType should never be assigned to a structure and is typically used  to reduce the number of parameters stored. It can be used in any interaction, but the best use of it is in the torsion case. If the torsion is described by 4 atoms I,J,K,L; often the torsion parameters are not very sensitive to the end I and L atoms. Hence in many forcefields you will see a lot of torsions terms with X for these types e.g. in Dreiding you will see "X C_3 C_3 X" and that might be used for all torsions where the central atom J & K are sp3 hybridized Carbons, regardless of what they are bonded to.
For forcefields like Dreiding, Forcite will look for an exact match of ForcefieldTypes, and if that fails will substitute one or more ForcefieldType for X and then look for that one etc. Look for "stepdown" or "equivalencing" in the online help.
Regards
Simon Miller
PS Please note that editing the .off file directly may have unexpected side effects and the Forcefield editor should be used whenever possible.
