We are currently using SLURM instead of Torque in our CentOS 6.3 cluster environment and are trying to use the SLURM wrappers to emulate Torque without success. We are able to take the output of Accelrys and run the job successfully from the Linux command line but the Gateway doesn't seem to recognize the environment is up and running. This ultimately causes the job to fail to execute.
Has anyone else tried to convert over to SLURM as a scheduler instead of using Torque and what steps did you have to go through to make it happen? Thanks.
