Dear everyone,
with the aim to check the exact potential parameters used using the AMBER ff implemented in MS 5.5 to simulate (by MD with Discover module) organic systems, I found problems to understand the exact potential form used for the torsion in relation to many references found in literature (as Cornell et al. JACS 1995, 117, 5179-5197..).
in order to be clearer..
here is the torsion form implemented in amber.frc (used by Discover)
#torsion_3 amber
> E = SUM(n=1,3) { (Vn/m) * [ 1 + cos(n*Phi - Phi0(n)) ] }
> m = multiplicity or total number of torsions centered on the same bond.
!Ver Ref I J K L V1 Phi0 V2 Phi0 V3 Phi0
1.0 1 * CT CT * 0.0000 0.0 0.0000 0.0 1.3000 0.0
that seems a bit different from the torsion form used for example in Cornell et al. JACS 1995, 117, 5179-5197:
E = SUM(n=1,3) { (Vn/2) * [ 1 + cos(n*Phi - Phi0(n)) ]
especially..in the (Vn/m) component....where in second expression it seems that m = 2 and that the multiplicity is n = 1,3.
the problem is that or I couldn't found the specific AMBER reference on which is based the amber.frc or something is not so clear..
Could you help me??
thanks in advance...
G
