The problems of Installing Materials Studios .
When I install the Materials Studios on the linux system ,the err as follows:
Bundled JRE is not binary compatible with host OS/Arch or it is corrupt. Testing bundled JRE failed.
WARNING: You have either chosen to cancel your installation, or an error has occurred.
Please Verify your usage is correct:
Usage: lp_setup [-silent] [-console] [-is:tempdir ] [-is:log ] [-P licensepack.installLocation=]
       -silent - installs the product in silent mode.
       -console - installs the product in console mode.
      -is:tempdir - allows the user to specify the location of your tmp dir.
       -is:log - allows the user to create a verbose log of your installation.
       -P licensepack.installLocation - allows the user to specify the location to install LicensePack
If usage is correct please refer to FAQ section of the LicensePack documentation or contact Accelrys Scientific and Technical Support.
The LicensePack documentation index is called LicensePack.html and is located on the CD.
Return Code: 1
LicensePack installation failed
And my the information of JRE is as follows:
java version "1.6.0_22"
OpenJDK Runtime Environment (IcedTea6 1.10.4) (rhel-1.41.1.10.4.el6-x86_64)
OpenJDK 64-Bit Server VM (build 20.0-b11, mixed mode)
The OS is like this :
LSBVersion: :core-4.0-amd64:core-4.0-noarch:graphics-4.0-amd64:graphics-4.0-noarch:printing-4.0-amd64:printing-4.0-noarch
Distributor ID: Scientific
Description:     Scientific Linux release 6.2 (Carbon)
Release:  6.2
Codename:      Carbon
What's the matter ? Any suggestions.
