Structure is distored after NVT dynamics
Hi everyone
I construct a phenanthrene molecule and opimized its structrue.Then I heat it to 1600k with NVT dynamics,but the structure is distored(the carbon atoms are not at the same plane),then I use NVE dynamics to relaxed,but the strucuture is still distored.But as far as I know the carbon atoms should be at the same plane.What is wrong with my calculation.The forcefiled is PCFF,the thermostat is Berendsen with decay constant 0.1.
Sincerely
Li
Answers 2
CM
CM 2015-04-15
Do you really expect the structure to remain undistorted at 1600K? If you continue with NVE afterwards the energy and temperature are still in there and I do not expect that anything really changes. The E means that the energs should not chnage.
B武
B武 2015-04-15
Hi Carsten
Thanks for answering my question.The structure I find the in book is plane, but the book does not mention about temperature,so I am not sure whether the structure is distored  at 1600k is normal.Is the equilibrium state only criterion to judge the whether the structure is reasonable?
