strange ouput
Dear all
i designed  a new MOF. i had its binding energy from  DFT  calculation .to check the adsorption capacity, i loaded xyz file in   accerlrys sorption module .i opened a  project and  ran geometry  optimization and i ran  sorption module in same project and at 1k i got  average isosteric heat  2.6 kcal /mol . then another day i open a new  project and loaded the  same xyz file i got isosteric heat 0.8 kcal /mol  . i used modified UFF  for both run .if i ran same xyz file in first  project i got ~2.6 kcal/mol many times and in other project(folder), i  got for every time same ~ 0.8 kcal/ mol. Can any one tell what is the  reason  for difference ? which one is right result?
Thanking you
Amar
Answers 3
HP
HP 2010-11-14
The Sorption module uses a Monte Carlo approach to load guest molecules into the host. Consequently, there is some degree of randomeness to the calculations, but if the calculations runs for a long enough time, they should eventually converge to the same result each time. How many production and equilibration steps are you using? It sounds like you don't have enough.
It is important to make sure that you have run enough steps to converge. One of the outputs from Sorption is a graph of the various energy contributions as a function of step. Check that each contribution has converged to a constant value. If not, you will need to run more steps.
-george
HP
HP 2010-11-14
Dear george,
I am trying to find out the reason for this strange output for  more then 10 days. I changed number of step from 5*10^5 to 10^7, but i  did not find any change. I loaded the same  xyz file in an older project  with same forcefield (modified UFF), same  number of steps and specify  forcefield for each atom and then checked calculate automatically, ran  sorption module, i got  output ~0.8 kcal/mol, while same xyz file, same forcefield , every thing  is same , i loaded in a new project i got ~0.26kcal/mol. and Avg number  of particle is a bit higher in case of lower isosteric heat. I really  worried  about that result. i am unable to find the reason for that? please  someone give expert comment on this
  Thanking you
Amar
JD
JD 2010-11-17
Amar,
Yes that is strange. I would assume something about the input directives or structures has changed and proceed to look very carefully for those differences. You will find the input structures in the Input folder. You can also open up the "RUNNAME Calculation" file and inspect all the settings there.
If you still cannot see the problem, try running Calculation1 with Input2 or vice versa. To do this you will have to create a new folder and copy the Calc file from the first run and Input folder from the second run. Then you need to point the Calc box to these structures and click Run.
Let us know what you find out.
Best,
/Jason
