Dear all,
Very recently I've met qutie strange error when running MS2017 Forcite anneal simualtion on my Linux workstation (linux version:CentOS 7 3.10.0-123.13.2.el7.x86_64 x86_64) after some OS update with submission from windows client.
The error message is:
Dynamics calculation - Failed to load temporary document.
Task terminated : Fri Oct 27 15:43:06 2017
Total CPU time used by Forcite: 1:33 minutes (93.2s)
Termination status : Error
The strange thing is that the dynamics runs okay but the .xtd files are not accessable with following error:
An error occurred while opening a view onto the document: Failed to import document from PolyPFIID_5_units.xtd. - Unable to process XTD content - Element 'AtomisticTreeRoot' (ID=1) - Element 'Properties' (ID=) - Attribute='TotalEnergy' - Unable to convert the value '-nan' for type double: Error: Invalid Float
I've also found many -nan for following entry in the output .xtd files. One of the output .xtd file is also attached to this post.
TotalEnergy="-nan" PotentialEnergy="-nan" ValenceDiagonalEnergy="-nan" BondEnergy="95.7838992895076" AngleEnergy="355.252042619349" TorsionEnergy="-nan"
Force="-nan,-nan,-nan"
When I checked the server files, the std.err file shows:
Dynamics calculation - Failed to load temporary document (function/property "Compute") at -e line 25.
Thus I further search for the origin of the error message in the MS installation folder for all files, it turns out to appear in following binary files:
Binary file lib/libSMXDynamics.so matches
Binary file lib/libSMXPMPClient.so matches
Binary file lib/libSimulationsUtilities.so matches
I suspect it may be related to my recent OS update which make some of library dependency broken. Thus I furthe ldd the dependency of these MS library, the ldd outcomes are attached to the file.
Greatly appreciate if anyone can give me some hint regarding solving this problem since I cannot further figure out the source of the error at this stage.
Thank you and Best Regards,
yjmaxpayne
yjmaxpayne
