Dear All
I tried to use a same script to process a 2G trajectory and a 15K trajectory, I can run on server for the 15K data, but for the big 2G data I got the following error:
Unexpected server gateway error. Code 500 Description: Internal Server Error
Job failed during launch process, no results generated, no results downloaded, and project results folder has been removed.
My system is Windows server 2008 R2 Enterprise sp1. I'm using MS 7.0 now. When I was using MS 6.1, I ran the same script on server for 2G data with no problem.
Any one had the same issue? Any suggestion about that?
Thank you.
Regards,
Jingjing
