I am trying to understand how CVFF calculates torsion potentials in materials studio. According to force field manager, the torsion for my molecule is using 'Scaled Dihedrals'. I searched online, it says "it's the same as dihedral potentials except the barrier will be scaled by the number of torsions about the common bond J-K." I am not quite understand this. Can somebody explain this to me? Thank you!
Hi chao li,
To illustrate with an example, consider ethane for which cvff has the torsion term
h c3 c3 h S_DIHEDRAL 2.8450 3.0000 -1.0000
There are 9 combinations of h-c3-c3-h torsions. In the trans configuration, they each contribute 2.845 kcal/mol (since ½ [1 + cos(3 φ)] = 1 for φ = 0, ±120°), but the result is divided by the number of torsions, therefore the torsion energy is 2.845 kcal/mol.
Compare this with the functional form
h c3 c3 h DIHEDRAL 2.8450 3.0000 -1.0000
The reported energy in this case is the unscaled energy, 25.605 kcal/mol. You can verify this in Forcite by modifying cvff.
Regards,
Reinier
