I created a lipid bilayer using coarse grain dynamics and also created coarse garin structure of a ZnO nanocluster.
I am placing this nanocluster on the bilayer and while trying to run dynamics task in setup option of mesocite module with the following parameters:
Ensemble : NVE, Temperature : 298.00 K, Timestep : 20.00 fs, Number of steps : 50000, Duration : 1000 ps, Initial velocities : Random
getting an error message:
Dynamics calculation - Aborting dynamics.
An unphysical integration step (>100 Angstroms) has been detected. Try relaxing the structure with geometry optimization, reducing the time step, reducing the temperature or a combination of these.
I have tried a lot to resolve this error but could not; getting same message again and again.
Kindly suggest what should I do to run dynamics.
Regards,
Deepali Sharma
Have you tried running Geometry Optimization before Dynamics? And if so, did the energy converge?
Running dynamics straight after construction typically fails with the reported error, since the forces are too high to integrate this, at least with a default time step.
Best,
Reinier
