hi all,
i want to reproduce work GCMC part of paper of H2 adsorption in MOF-5. energies are calculated by UFF force-field. they modeled H2 molecule by placing a ghost atom with charge -0.966e at the center of the H2 molecule, and charge +0.483e on each H. for H2 molecules. The force field was modified, a repulsive potential U=D0exp[y(1-R/R0)] was used .R=inter atomic distance. how to assign that central negative charge on H2 (should i make 3 body system?) and how to modify repulsive potential in UFF in Accelrys? reference paper is attached with this
Message was edited by: Stephen Todd - Removed PDF. Please do not post copyrighted material into the Community. Please post a link to the paper instead.
concerning the first part of the question: Yes, you have to use a three-body model. For most of the typical models used for H2, only the central pseudo-atom (with the negative charge) should be van-der-Waals "active", i.e. associated with potential parameters that contribute to the dispersive intermolecular interactions. In Materials Studio, you need to associate an atom type from the force field with every atom, so you will have to introduce a "dummy" atom type that contributes zero to the interaction energy for the two other sites, which coincide with the atomic positions. You can easily create a new atom type in your force-field file using a text editor.
Concerning the second part, I am somewhat suspicious about this. Why should one use a purely repulsive potential to represent the H2-H2 interaction? It is stated in the paper that this is done "to prevent clumping the of H2 molecules", but they will not clump when a normal Lennard-Jones potential is used, because the LJ potential contains both a repulsive short-range and an attractive long-range part, which is more realistic. It is, however, possible to replace the repulsive r^-12 term of the LJ potential by an EXP term. This corresponds to the Buckingham potential, which can also be implemented in the force-field file. The easiest to find out who this is done is to play around with the Force Field editor.
May I also draw your attention to a more recent paper where Sorption was used to model H2 adsorption in MOFs (accidentally co-authored by myself). It cites plenty of other publications, some of which may be useful for you.
Good luck!
Michael
Sorry for posting the PDF - I did not really think about copyright issues.
This is the link to the paper:
http://onlinelibrary.wiley.com/doi/10.1002/cphc.200900459/abstract
sir
i am sending hydrogen input file for adsorption in MOF-5,can u check those attached files that wheither those are coorect input file for 2 site without charged model and 2 site charged model..
I cannot say much from the files you provided. The positions are ok, but there are no charges assigned. Maybe this is due to conversion to XYZ format?
Please note that the model without charges often uses a "United Atom" approach, i.e. only one single site for the van der Waals interactions. You should not use the hydrogen parameters from the UFF for this single site, but take e.g. the parameters derived by Buch, which appear in the literature very frequently.
A two-site model is used less regularly, e.g. in the work by Goddard and co-workers:
http://onlinelibrary.wiley.com/doi/10.1002/anie.200700303/abstract
Hope this helps
Michael
hi sir,
i went through your paper (http://onlinelibrary.wiley.com/doi/10.1002/cphc.200900459/abstract). i run the sorption module at 77 K using inbuilt universal force field . i got zero loading for MOF-74(CIF file obtained from reference mention in your paper) and h2 system. i want to change the value of Do and Ro so that i can reproduce your work. in material studio only dreiding can be modified? in https://community.accelrys.com/thread/1890 thread some force-fields are given. i select Dreiding n changed Do and Ro. as mention in your paper. i opened Module--->sorption-->calculation-->Energy-->force-field-->Browse-->choose forcefield. but imported forcefield is not showing while imported forcefield is still open in project window. so how to browse any imported force field.regarding fluid-sorbate interaction, we have to set Do and Ro from Lorentz berthelot mixing rule or material studio will automatically do this job?
thanks
Amar
Sorry, I cannot answer the question concerning the force-field editor. Probably you have to copy the modified force field to the folder where the other (default) FF files are, then you should be able to select it.
Concerning the mixing rules, I believe you have to modify the file manually. It is the line which reads:
VDW_COMBINATION_RULE ARITHMETIC
By default, it is set to "GEOMETRIC" for UFF and "ARITHMETIC" for DREIDING. When set to "ARITHMETIC", you get Lorentz-Berthelot mixing rules. These rules are applied automatically, using the Lennard-Jones parameters of the atom types.
Good luck!
Michael
sir ,
apart from help of material studio. is there any other source of study material where i can get more information
Your question is very general, but please consider the following review articles:
http://www.rsc.org/publishing/journals/CS/article.asp?doi=b803498m
http://pubs.acs.org/doi/abs/10.1021/ie800666s
http://dx.doi.org/10.1016/j.micromeso.2009.07.006
Best regards
Michael
Dear sir,
in your paper (chemphyschem 2009,10,2647-2657) you mentioned the C_aryl parameter. but when one would use accelrys then it could not accept C_aryl. so is it same as C_R? in accelrys where to incorporate this thing?accelrys would take only standard symbols like C_3,C_2 etc.what is size of unit cell you taken for adsorption isotherm and quality of simulation (coras/medium /fine/ultrafine)?
thanks
Amar
sir one last help. i edited Dreiding forcefield in forcefield editor(forcite manager) i changed the values of Do and Ro for C_R, O_R,O_2,,N_R,Cl, and H_. added the values of Do and Ro for H_2,Mn6+2,Cu3+1,,Zn3+2ri tried to reproduce your work(adsorption at 77K) for UMCM-150 and hydrogen. i got uptake upto maximum 1.4 % while in paper its around 4wt% at 60 bar.i am unable to modify UFF because forcite editor not supporting it.so can u send your forcefield file or help me so that i can reproduce your work
Concerning the C_aryl, I just changed the parameters of C_R to the corresponding value. Note, however, that C_R is sometimes assigned to carbon atoms which are not part of an aromatic ring, e.g. in a carboxylate function. You manually have to change this force field type to C_2.
Concerning the "quality" of the calculation, you should compare different choices and see how much the results change. "Coarse" is probably too coarse, I never used it, but "Medium" or "High" should be ok. Similarly, you should compare the results for a normal unit cell and a 2x2x2 supercell. If you do not find a difference, the normal cell should do.
