Hello, communitors
I tried to calculate electronic density differences with perl script in dmol3 (you can download it from community site)
I edited few lines and tried to calculate electronic density differences however in 232 line it was error when i did debug.
the error message is following as Failed to export document to C:\\Users\\KANGSUNWOO\\Documents\\Materials Studio Projects\\New-Graphene with CdSe Calc Files\\~TASK_1708\\GwithCd3Se3.xsd.
- bad allocation in DMol3.Energy (function/property "Run") at -e line 232.
failure running DMol3 on GwithCd3Se3
the parts of perl script, which are related to error message are following as (the underline and bold type line is 232)
# This routine runs DMol3 on the input document and checks for errors.
# If "type" eq "energy" it does single-point energy
# eq "optimize" it does optimization
# It it completes ok it returns 1
# If job fails then it prints a message and returns 0
my (\\\$doc, \\\$type) = @_;
my \\\$output;
my \\\$RanOK = 0;
# delete any existing field with the same name
my \\\$fieldOld;
eval {\\\$fieldOld = \\\$doc->UnitCell->Fields("\\\$fieldName");};
if (\\\$@) {
# Error accessing field, hence field does not exist
#print "No field named \\\$fieldName from document ". \\\$doc->Name . "\\n";
} else {
# delete this field
print "Deleting old field named \\\$fieldName from document ". \\\$doc->Name . "\\n";
\\\$fieldOld->Delete;
print "Starting DMol3 job for " . \\\$doc->Name . "\\n";
if (\\\$type eq "energy") {
eval {\\\$output = Modules->DMol3->Energy->Run(\\\$doc);};
} else {
print "Unkown type of calculation requested: \\\$type\\n";
\\\$RanOK = 0;
return \\\$RanOK;
if (\\\$@) {
# Some error occured
#print error message and move on to the next element
print "!!!!!!!!!!!!!!!!!!! ERROR !!!!!!!!!!!!!!!!\\n";
print \\\$@;
\\\$RanOK = 0;
} else {
# Calculation has completed successfully, carry on
\\\$RanOK = 1;
print "Successful DMol3 completion for " . \\\$doc->Name . "\\n\\n";
return \\\$RanOK
if here is someone, who tried to this perl script calculations in dmol3, know this one
please give me detail information. (i really need detail explaination)
I also attached files of perl script
