Problematic: nucleotides with high energy even at great distances
Hi
I had observed a problem with DMOL3 of Materials Studio. In truth I hope it's only configurational mistake.
My proposal is to calculate the interaction energy between ribosomal nucleotide (charge -1) and positively charged drugs (charge +5). Using the setup GGA / PBE-TS-DNP-Charge +4, and from a simple technique of Molecular Fragmentation - Energy of interaction = E (nucleotide-drug) - E (nucleotide) - E (drug) -obtained results with extremely high energetic (above -100kcal/mol). Subsequently, I've distanced residue from drug about 1000 ångström and did the same energy calculation. Chemically, the interaction energy between them should reach values ​​close to zero, but the ones that I have obtained still very energetic values​​. I have redid the same calculation, but using nucleotide and drug without charges, and finally obtained values ​​near zero. I believe that the electrostatic component of the energy value is overestimated by DMOL
What do you think?
Answers 2
HP
HP 2012-06-07
I suspect the problem is that the charge state of the complex is not the same as the fragments. When you run nucleotide(-1) and drug(+5) each molecule is clearly charged the way you want it. Whenyou run (nucleotide + drug) (+4) you can't control where the electrons go. I suspect that the drug molecule doesn't have a +5 charge, but it takes some electrons from the nucleotide. You can test this by calculating Mulliken or Hirshfeld charges and adding up the atomic charges on each fragment.
Does the drug really have +5 charge? That seems incredible to me.
-george
JD
JD 2012-06-07
Yes +5 is a strong charge for a drug molecule. With such a strong charge in solution it would likely attract counterions that would reduce the interaction.
