Hello Dear MS users,
I try to calculate the energy of ethane C-C single bond breaking. I use DMol3 with functional GGA/PBE and basis set DND. The following is error in my output file.
####ERROR####
There should be 1 Constraints but none found on OPT file!
Peak memory usage: 218952 kB on current thread
... Calling mpi_abort ...
Errors from parallel task 3:
####ERROR####
Peak memory usage: 225020 kB on current thread
Errors from parallel task 4:
####ERROR####
Peak memory usage: 212880 kB on current thread
How can I solve this problem?
Thank you very
####ERROR####
####ERROR####
####ERROR####
Thank you very
this is getting way too complicated. Can I reiterate that Materials Studio does not support the DMol3 scan_pes task, there is no support for it, and we never promised that it works in any documentation.
Instead, we have a very powerful set of scripting tool, which allow you to do many more things than simply constraining single bond lengths and then having to sort through the outmol file in detail.
I have written an example script that does exactly the calculation you are looking for and returns a study table with a summary of the results. The script and an appropriate input file is attached, feel free to add any particular property that I might have missed.
All the best,
Felix
your question is difficult to answer from the information you provided - there are many different ways to do this calculation and quite a few of them involve constraints.
I gather that somehow you managed to assign constraints in the input deck, but then DMol3 struggled to read them when required.
Can you please post a full set of input/output files where this problem occurs?
Thanks,
Felix
The following is the input setting. And the file is output file.
# Task parameters
Calculate scan_pes
Opt_energy_convergence 1.0000e-006
Opt_gradient_convergence 8.5200e-004 A
Opt_displacement_convergence 9.5100e-004 A
Opt_iterations 500
Opt_max_displacement 0.0100 A
Initial_hessian improved
Symmetry off
Max_memory 2048
File_usage smart
Scan_option optimization
Scan_dim_1
Distance 1 2 0 0 1.528 2.528 21
# Electronic parameters
Spin_polarization restricted
Charge 0
Basis dnd
Pseudopotential none
Functional pbe
Aux_density octupole
Integration_grid medium
Occupation fermi
Cutoff_Global 3.3000 angstrom
Scf_density_convergence 1.0000e-005
Scf_charge_mixing 2.0000e-001
Scf_iterations 50
Scf_diis 6 pulay
# Print options
Print eigval_last_it
# Calculated properties
thanks, that certainly helped to figure out what's going on. To run this particular calculation anyway, please add the line
opt_coordinate_system cartesian
to your .input file and it will work fine.
All the best,
Felix
I add the line to my input file, but it still can't run.
The following is the error in my output file.
INPUT_DMOL error: unrecognized keyword(s): opt_coordinate_system cartesian
Thanks,
Jay
this seems strange, the keyword is spelled correctly - but please refer to the keyword documentation if you are unsure.
The only thing I can think of is that you may inadvertently have put the line into a keyword block where it was expecting a follow-up keyword blank line (for example for your PES scan block). Ideally, this keyword needs to be part of the other opt_ ... keywords, then it should work fine.
If that is not the case, please post the entire input file and I will have a look.
Best,
Felix
The file is my input file.
Thanks,
Jay
I fully admit that the error messages you get are not overly helpful, and I am not sure what one could do about that. However, if you remove the ` character from the very first line of your input file it should start to work again.
Best,
Felix
After I remove the character, the result has no change.
It still can't recognize the keyword
Thanks,
Jay
the attached input file appears to work fine for me.
Best,
Felix
I have tried version 7.0 and 2017 R2. However, both of them get the same error. Can you tell me which version you are using?
Thanks for your advise.
Best,
Jay
Thanks for your help and script.
The job can work after using the script.
Bests,
Jay
