Hi, all
I do some multiplicity calculations recently using DMol3 in MS 5.5, the system is 17-Os-atom-cluster.
problem is the optimization step 2 always failed because SCF not converged. I try to set increase SCF max. iterations and smearing value, but the error is still as before.
following is my input, could someone help me?
# Task parameters
Calculate optimize
Opt_energy_convergence 1.0000e-004
Opt_gradient_convergence 2.0000e-002 A
Opt_displacement_convergence 5.0000e-002 A
Opt_iterations 1000
Opt_max_displacement 0.3000 A
Initial_hessian improved
Symmetry on
Max_memory 2048
# Electronic parameters
Spin_polarization unrestricted
Charge 0
Basis dn
Pseudopotential dspp
Functional gga(p91)
Aux_density octupole
Integration_grid coarse
Occupation thermal 0.0050
Cutoff_Global 3.6000 angstrom
Scf_density_convergence 1.0000e-004
Scf_charge_mixing 0.2000
Scf_spin_mixing 0.5000
Scf_iterations 500
Scf_diis 6 pulay
# Print options
Print eigval_last_it
# Calculated properties
Frequency_analysis on
