Dear MS users,
I am confused by Dmol3 calcuations with peptide. After the geometry optimization, I got the stranger model as follows:
Here are the input files:
# Task parameters
Calculate optimize
Opt_energy_convergence 1.0000e-004
Opt_gradient_convergence 2.0000e-002 A
Opt_displacement_convergence 5.0000e-002 A
Opt_iterations 100
Opt_max_displacement 0.3000 A
Initial_hessian improved
Symmetry on
Max_memory 4000
File_usage memory
# Electronic parameters
Spin_polarization unrestricted
Charge 0
Basis dn
Pseudopotential dspp
Functional pbe
Aux_density octupole
Dftd TS
Integration_grid coarse
Occupation thermal 0.9000
Cutoff_Global 3.0000 angstrom
Scf_density_convergence 1.0000e-004
Scf_charge_mixing 2.0000e-001
Scf_spin_mixing 5.0000e-001
Scf_iterations 500
Scf_diis 8 pulay
# Print options
Print eigval_last_it
# Calculated properties
I wonder to know what is wrong with the calcuation
the problem is in the following line in your input file:
If you are looking only at molecules, then "Occupation fermi" is the correct option, otherwise try the default smearing.
Best,
Felix
Thanks so much. I would try it again. And if, the molecuele interacts with a inorganic surface for example calcite, should I use the default occupation settings?
Hi
If the surface is metallic, use the default settings for metals, if it is insulating also use occupation Fermi.
Best,
Felix
