Hello everybodey,
I optimized a mxene unit cell in Dmol3 and then calculated the band structure a
What is the cause and how can I solve the problem?
Hello everybodey,
Hi, you have a significant density of states at the Fermi level, suggesting that your calculations predicts this material to be conducting. In this case, there is no band gap to report and neither the DMol3 output nor the visualizer will be able to give you information about highest occupied and lowest unoccupied states in the electronic structure as there is a smooth transition between the two.
