Dear all,
I have some questions about the pseudopotential. I found some articles mentioned that in order to get more acurate band structure, the sX functional should be implemented. Nevertheless, the reciprocal space values of cutoff energy installed Materials studios and that of the article are different, i.e. Zn is 600 eV in the program but 680 eV for the paper so that I tried to change the number of it. Help files, as same as the article, said that 'Opium' is needed for manipulation of '.recpot'. I have been through the site <http://opium.sourceforge.net> but I couldn't download the file called Xsgrace which is the prerequisition of the installation. Moreover, I couldn't locate ".recpot" in my computer.
In order to manipulate or make changes in those files, what should I have to do? Would you mind give me some hints to follow.
Best regards,
LEELACHAO Sirichai
Dear Sirichai,
you can find the recpot files on the client computer in the folder as follows: C:\Program Files (x86)\Accelrys\Materials Studio 5.5\share\Resources\Quantum\Castep\Potentials
This directory is not available on the server.
If you choose the ultrafine option for the energy cutoff value you will get 660 eV for Zn. You can definitely increase this value if you choose so. You can run CASTEP using sX functional in Materials Studio (MS) as well, although it depends on which version of MS you are using.
Best regards, Alex.
