Hi there,
At the moment i am dealing with gas/vapour adsorbents (preconcentrators) for trace substances in the air. This is necessary due to the fact that a lot of substances cannot be detected (by e.g. GCMS) as long as their concentration unterruns the ppb/ppq region. The basic idea is to tailor an adsorbent that allows the specific adsorbtion (physisorption) of a substance (by shape complementarity or non-covalent interactions) and its release after a heating ramp. This heating will release the accumulated substance on the adsorbent.
I want to carry out some adsorption modelling of vapour traces (e.g. Xylenes and Nitrobenzenes) on different metal organic frameworks (MOFs). If the method proves to be good, i want to use it in order to screen a MOF library with respect to vapour adsorption. The question arising is: How do i put this dilution fact into an atomistic model. In the literature, they simply employed the sorption module to calculate henry constants and adsorption isotherms in order to determine sorption trends for these trace materials. However, this model does not accomodate for the fact that there are other competing substances (like nitrogen, cabon dioxide or water) in the air. Does anybody know, how one could combine MD and GCMC in order to describe the specific contentration factor of such sorbent materials?
Thank you in advance!
Literature:
(1) Greathouse, J. a; Ockwig, N. W.; Criscenti, L. J.; Guilinger, T. R.; Pohl, P.; Allendorf, M. D. Physical chemistry chemical physics : PCCP 2010, 12, 12621-9.
(2) Xiong, R.; Odbadrakh, K.; Michalkova, A.; Luna, J. P.; Petrova, T.; Keffer, D. J.; Nicholson, D. M.; Fuentes-Cabrera, M. a.; Lewis, J. P.; Leszczynski, J. Sensors and Actuators B: Chemical 2010, 148, 459-468.
(3) Wilmer, C. E.; Leaf, M.; Lee, C. Y.; Farha, O. K.; Hauser, B. G.; Hupp, J. T.; Snurr, R. Q. Nature Chemistry 2011, 1-7.
I don't have alot of experience with sorption, but I guess a simple way to approach this would be to prepare framework models that already contain (adsorbed) molecules of for example nitrogen, oxygen, water etc. in the appropriate ratios predicted by their adsorption isotherms (if availible) with the total number of sorbed molecules correlated to the atmospheric conditions of temperature and pressure at which the MOF's are to be applied. With the "pre-loaded" model, which may perhaps then be subjected to MD for proper equilibration, you can then just perform a sorption simulation with the relevant sorbate, wherein the adsorbent should then have a deminished sorption capacity towards the sorbate in question, and one can do this maybe at different (relatively low) fugacities of the sorbate and then use the results to extrapolate to the concentration region in question.
I'm not sure if this method is physically sound, but in this case, where the sorbates are very dilute, you can expect the asorbents to adsorb more of the matrix molecules from the atmosphere even though the MOF might have a higher sorption selectivity towards for example Xylene, because of the larger gradient that exists for mass transfer of the matrix molecules.
Regards
You should consider, however, that the more strongly adsorbing species (say, xylene) will easily replace the more weakly adsorbing species (say, nitrogen) due to the much stronger interaction in the real system. If you assume a static configuration of your MOF with nitrogen molecules in it, and then run a simulation of xylene adsorption, you are likely to underestimate the capacity for xylene, because the N2 molecules will "block" some adsorption sites.
But it is certainly not a trivial problem, so different ways should be explored. My suggestion would be to start of at tractable molar ratios (may 100:1), then modify the ratio and evaluate how the selecitivty changes.
Cheers,
Michael
