Dear MS Users,
I am using Forcite for MD simulations of an organic compound using the COMPASSIII force field. It seems that there is a bug for the forcefield parameter n2= (nitrogen, two bonds). Every time a nitrogen is present with this forcefield parameter, the MD simulations become unstable at some point and result in an error message "An unphysical integration step (>100 Angstroms) has been detected". Reducing the time step to 0.1 fs or optimising the structure does not help.
Has anyone had a similar problem?
Best Wishes
Marek Sierka
The error message suggests a large force added to atoms which led a large displacement of the atom in only single integration step. Which structure (solution, amorphous polymer, etc.) are you investigating? Task: Geometry Optimization can solve the problem for such structures. The default value 500 as Max. iteration will sufficient to relax highly distorted structure.
Thank you for the suggestion, but the initial structure is well optimised and the initial forces are low. In fact, I used the value 100000 as the number of max. iterations for the Geometry Optimization task.
Could you please zip the complete folder of the failed run and add it to the SR.
Please also add the .xsd file from which the run was started.
Thank you, here is the whole directory.
COMPASSIII does not really know about the oxime group.
Could you please assign different forcefield types, e.g. o2 on oxygen or n on nitrogen. That seems to work better.
