Dear all,
Recently, I encountered an error related installation of Materials Studio 2016.
The program will be installed on the LINUX, and its OS is CentOS 7.8
The error message was:
/home/biovia/CD_MS/MaterialsStudio2016/LicensePack/lp_setup_linux.sh: line 1735: warning: here-document at line 1735 delimited by end-of-file (wanted `/dev/null')
Couldn't get environment information from lp_echovars: 256 at /home/biovia/MS/MaterialsStudio2016/share/Install/Scripts/MSConfig.pm line 304.
Materials Studio configuration failed
The first message was printed at the beginning of the installation, and at the end of the installation, the latter printed.
If someone knows how to fix this, please let me know.
Thank you.
P.S, I attached the whole installation log below.
[biovia@hpc2019 ~]\\\$ ./CD_MS/MaterialsStudio2016/install
Performing per-user installation of Materials Studio 2016. Restart this
installation as root if you wish to perform an RPM-based installation.
Please enter the location in which to install Materials Studio 2016
The location where Materials Studio will be installed is
[/home/biovia/BIOVIA] /home/biovia/MS
The BIOVIA License Pack is required in order to run Materials Studio 2016.
Please enter the location of a License Pack installation, or an empty directory
into which the License Pack will be installed.
[/home/biovia/MS] /home/biovia
/home/biovia does not appear to contain a supported License Pack installation. Would you like to
install it to that location? [Y/n]
[Y] y
Would you like to specify an alternative Gateway port number (default is 18888)
[N] y
Please enter the port number
[18888] 21715
Do you wish to start the Gateway service after installation? Answer no here if
you wish to configure security settings before starting. (Y/n)
[Y] y
Running LicensePack installation...
Initializing InstallShield Wizard........
Launching InstallShield Wizard........
BIOVIA License Pack 7.6.12 - InstallShield Wizard
Welcome to the InstallShield Wizard for BIOVIA License Pack 7.6.12
The InstallShield Wizard will install BIOVIA License Pack 7.6.12 on your
computer.
To continue, choose Next.
Dassault Systemes Biovia Corp.
http://www.accelrys.com
Press 1 for Next, 3 to Cancel or 5 to Redisplay [1]
BIOVIA License Pack 7.6.12 Install Location
Please specify a directory or press Enter to accept the default directory.
Destination Directory [/home/biovia] /home/biovia
Press 1 for Next, 2 for Previous, 3 to Cancel or 5 to Redisplay [1]
Select the features for "BIOVIA License Pack 7.6.12" you would like to install:
To select/deselect a feature or to view its children, type its number:
1. [x] LicensePack
2. [ ] Compatibility LicensePack
The Compatibility LicensePack is required for supporting BIOVIA software
shipped with License Packs 6.x or lower and to support IRIX and Solaris
platforms. See License Pack documentation for complete list of BIOVIA
software supported by this License Pack.
Other options:
0. Continue installing
Enter command [0]
BIOVIA License Pack 7.6.12 will be installed in the following location:
/home/biovia/LicensePack
with the following features:
LicensePack
for a total size:
150.6 MB
Installing BIOVIA License Pack 7.6.12. Please wait...
0% 25% 50% 75% 100%
Creating uninstaller...
Finalizing the Vital Product Data Registry. Please wait...
Configuring License Pack
The InstallShield Wizard has successfully installed BIOVIA License Pack 7.6.12.
Choose Finish to exit the wizard.
Press 3 to Finish or 5 to Redisplay [3]
Running installation ...
Running ConfigureMaterialsStudio.pl
ACCELRYS_LIC_PACK_DIR: Undefined variable.
