Hi there,
As you are hopefully aware, Materials Studio 4.2 has just been released with lots of new scripting functionality. Below is a list of some of the new enhancements I wanted to highlight!
General:
New API for the Materials Visualizer:
Modules:
Happy scripting!
Best regards,
Stephen
General:
- Performance improvements on memory usage - some repetitive operations were using large amounts of memory
- Script viewer - highlights matching and mismatching braces, automatically inserts closing braces
- Return values for many objects and modules (allows you to easily get the text or trajectory document associated with a calculation)
- WriteLevel - allows you some control over what documents are written out during a calculation(eg chart and text documents).
- Polymer and dendrimer builders
- Layer builder
- Crystal builder
- Surface builder and cleave surface
- Calculate conolloy and solvent surfaces
- Create fields, slices, isosurfaces, and field probes
- Hydrogen Bond calculations - control over donor and acceptor definitions.
Modules:
- DMol3 - All tasks available from the UI are available from script
- Polymorph - All tasks available from the UI are available from script
- Reflex - Reflex QPA, Powder Refinement, and Powder QPA are available from script
- Forcite - a new Forcite API has been introduced, making a consistent task based API for all modules. The 4.1 API should still be supported but there is a known issue with CalculationQuality command - this should be changed to Quality for compatibility with 4.2. Velocities can be written and read from the datamodel.
Happy scripting!
Best regards,
Stephen
