Launchin CASTEP by RunCASTEP.bat on 32 CPU parallel ...
I need to run the CASTEP code from batch file (Windows 10).
I use the RunCASTEP.bat -np 16 seed_name syntax. This works.
I have a PC with 32 fyzical, 64 logical procesors ...
After usinng RunCASTEP.bat -np 32 seed_name command, CASTEPS does not run correctly - looks like some zombie mode with no results and infinite hang in memory ...
With identical input the -np 16 works OK ....
I am sure this is not a memory issue (16 CPu need abut 16 GB, I have 126 GB).
Is this a known limit/bug ?
Michal Husak UCT Prague
