Interaction between fixed atoms
I am simulating a system containing several thousand fixed atoms that apply confinement to a polymer. Now I have the problem that the required CPU-time is extremley large, even when using very few free atoms. My guess is that Discover (and probably also Forcite) calculates the interactions among the fixed atoms without moving them. This, however, causes unnecessary huge calculation times since the largest amount of atoms is made up of fixed atoms for which the calculated forces are useless...
Is there any way to turn off the calculation among fixed atoms?
M. Brodeck
Answers 3
CM
CM 2010-07-19
Dear Martin,
I did not check the code but for the things I tried (10x10x10 Diamond supercell) the run runtimes differed significantly for a system with all atoms allowed to move and a system where only two atoms are allowed to move for both Forcite+ and Discover -> they are not calculated I would say.
Kind regards,
Carsten Menke
HP
HP 2010-08-19
Dear Martin,
Carsten is correct both Forcite and Discover will avoid calculating energies & forces between fixed atoms. There is one exception to this in Forcite using the Ewald summation where the implementation has to explicitly subtract out the fixed-fixed contributions in order to obtain a consistent energy & forces with the other summation methods.
Regards
Simon Miller
MB
MB 2010-08-23
Thanks for the replies!
