Using Dmol3 dynamic simulation, I want to recreate a progressing increasing electric field, so I start with a dynamic simulation with a null field; then, taking the resulting .xsd file, I use it to start a new simulation with a field of certain value, ie 0,005au in y direction. And so on. Is this a correct procedure? Does it really start the new simulation from the final configuration of the previous one, or should I impose particular conditions, such as atomic velocities, atomic coordinates, etc?
How does the program take into account the initial conditions? are they all included in the .xsd file?
Hi Claudia,
Yes the procedure is correct. Yes it really does start the new simulation from the final config of the previous one. The XSD file in the output folder holds the final structure so the coordinates should be different from the input structure. In cases where the difference is subtle, you can check by labeling the atoms by position.
If you want to be extra precise, you can specify the velocities at the start of each run via the DMol "user_defined" keyword option as described by George in the previous thread on this subject. You will have to grab the velocities from the .outmol file of the previous run. This is a bit clunky admittedly (as opposed to Forcite for example), but it is doable.
Best,
/Jason
