Dear Sir or Madam:
I often experience this kind of problem.After a MD simulation was finished using Forcite, it should be there is a trajectory file in the reslut folder. But When I open the .trj file, it's found that there is only one frame. therefore, I open the result folder and tried to import the hidden .trj file (which is as large as almost 4.0GB), there's a error reminder" Cannot open MSI file..." .
Since it usually takes several days to finish a job, I cant afford to run it again when experiencing this problem. In this case, what measures can be taken to remedy this problem?
Thanks a lot in advance!
Best regards,
Welsley
