Dear all,
I want to know if it is possible using Dmol3 to calculate metal-ion adsorption on substrates, such as the Fe3+ adsorb on graphene instead of Fe atom. I know the charge can be set at the Setup tab of DMol3 Calculation dialog, where can specify the total charge on the molecule or unit cell. However, I just want to add charges to the adatom. In some chemical software, such as Gaussian, charges can be added to a specific atom. So, I want to know can Dmol3 does this?
Actually, I do not know what is the difference between adding charges to the whole system and a specific atom. I think even just adding charges to a specific atom, the charge still diffusion to the whole system after relaxation.
Best, Pan
Hi, all DFT codes optimize the charges on different atoms. Some codes do allow you to set specific initial charges to get a better initial density. In your case, it would likely be better to set the total charge and an initial spin on the Fe atom. At the end of the calculation, you will still have to check where charges are located. To do this, please select population analysis in the property section and then choose Mulliken and/or Hirshfeld charges.
After you are done, you can analyze these on the DMol3 Analysis dialog (Population analysis | assign charges) and then add labels to each atom.
Dear Felix, sorry for late reply because I can not log in to my account for a long time. Thank for your detail answer and I get your points. Thanks again! Have a nice day! Best, Pan.
