I have two machines on which Material Studio is installed. I have synced the "Materials Studio Projects" folder between these two machines. This means that a project with name "xyz" has "xyz.stp and "xyz Files" which are synced and identical between these two machines.
PROBLEM: If i have trajectory file on one machine (say M1) for this Project then i can visualize the trajectory on M1 using Animation Tool. However, although all files are copied on second machine (M2) and i see the trajectory file with *.xtd extension on M2, even then the "Animation Tool" doesn't become active and hence i cannot visulaize the animation on M2.
Is it possible that i need to sync some other folder outside the "Materials Studio Projects" folder for successfully seeing the trajectory on either machines?
Thanks.
best,
nitin
