Hi everyone,
I’m trying to calculate properties like band structure and density of states using doped transition metals. I’m unable to get the bandgap value. Instead, I get separate graphs for alpha and beta spins when I used this setup for my calculations.
- Choose Modules | CASTEP | Calculation from the menu bar to display the CASTEP Calculation dialog.
- Select the Setup tab.
- Check the Spin polarized checkbox and check the Use formal spin as initial checkbox.
- To optimize the spin value, select the Electronic tab and click the More... button to access the CASTEP Electronic Options dialog.
- Select the SCF tab.
- Uncheck the Fix occupancy checkbox and check the Optimize total spin checkbox.
I’d like to know the exact setup required to combine both spins into a single graph along with the bandgap value.
As I've performed the same calculations on an undoped structure but not enabling the spin polarisation, I get both spins on the same graph with the bandgap value included.
Any guidance would be greatly appreciated!
Thanks
