Hello all,
I am currently trying to solve the lattice energies of three phases of a cobalt based MOF that differ based on levels of hydration. I am first geometry optimizing using Forcite and MACE-MP0b as my forcefield which has been successful. I am then using DMol3 geometry optimization to get a snapshot of the lattice energy using DFT. I am using GGA PBE as my functional and using the conditions of doi.org/10.1002/anie.202302996 for the DMol3 to see the changes in Gibbs Free Energy between the three phases. I have tried to change parameters such as smearing, SCF cycles, and convergence tolerance, and although the convergence graph shows that the last 20-30 cycles give energies within 0.1 Ha of each other, it runs out of iterations and ultimately fails. If anyone has any tips that would help I would really appreciate it!
In case you hadn’t seen it, yet, I’d encourage you to go through the following topic in the MS Help, where (SCF) convergence in DMol3 is explained in detail, and tips are offered for challenging systems:
DMol3 > Theory in DMol3 > Converging SCF
Hope it helps,
Jian-jie
Do you also optimize the cell?
Could you please do this in Materials Studio:
1. Close all documents in Materials Studio.
2. Make a clean directory.
3. Copy the Forcite COMPASS into this directory. Here I assume all subsequent runs are copied as well.
4. In the copy keep only the the runs with the directories which lead to the DMol3 run(s) to which you refer.
5. Copy the original .xsd file from which the Forcite COMPASS run was started into new directory as well.
6. Zip the directory from 2.
7. Add the resulting .zip file to the SR.
