I am attempting to do a Geometry Optimization (through Forcite) and I wish to constrain the angle around a center Cu atom to keep it square planar.
Whenever I attempt to refine the structure, these angles become grossly distorted to form a Cu center that I would consider to be non-physical.
If anyone has any experience refining structures while retaining this type of motif, whether in Forcite or another model, that would be an asset to me.
Thanks,
Ben
Hi
There is no bond or angle contraints but you can add restraints I.e. rather than fixing the angle there is an energy penality for a deviation from the set angle.
BTW which forcefield are you using?
Regards
Simon
Thanks for your quick answer and sorry for the very late follow up question and to answer your question, I am using the Universal forcefield.
How does one go about implementing energy penalties using forcite?
Hi
You will need to create restraint, either distance, angle or torsion depending on your requirements.Thread 20861 describes how to do this for a torsion, but distance and angles are similar.
You can also do this via scripting. Search on keywords CreateDistance, CreateAngle, CreateTorsion, CreateRestraint in the online help.
Regards
Simon
