Hello all,
I would like to do Forcite RDF analysis of a NaCl solution. I did the following steps:
1. Sketch water. The optimize using Forcite/Geometry optimization with COMPASSII. save as water.xtd
2. Sketch Na+, save as Na.xtd
3. Sketch Cl-, save as Cl.xtd
4. Amorphous cell calculation to mix water.xtd, Na.xtd, and Cl.xtd
5. Dynamic simulation using NPT using COMPASSII
6. Select the trajectory of step5, define sets, e.g., Edit/Find patterns/ Pattern document: water.xtd.
6. Do RFD analysis using set water-water
However, I got the error message: "Radial distribution function analysis failed.
There are not enough particles for a RDF analysis. At least one particle or centroid is required"
Do you know why it is? and can you please suggest a solution?
Thank you in advance!
Best,
Trang
