Hello community,
I followed and completed the "Generating a MS Martini 3 Forcefield and Bead Topology" tutorial. I have a few questions during the practice.
- Is there a general rule for determining which atoms should be grouped into a motion group and then mapped to a bead? In the tutorial, the CA bead represents four carbon atoms, which seems consistent with a standard Martini mapping. However, the NC, PO, and GL1 beads each contain more than four heavy atoms, while the CB bead contains only three carbon atoms. How should these discrepancies be interpreted when defining bead mappings?
- I manually assigned Martini force field types to all beads. Is there a specific reason to run the Force Field Generator script to create the .off file? If the Martini bead types have already been assigned correctly, can I simply select the Martini force field from the Force Field dropdown menu in the Energy tab instead of generating a custom force field file?
- A minor issue I noticed: After running the Force Field Generator, the force field type assigned to each bead is identical to the bead name itself. In the tutorial, the bead names and force field types appear to be different, as shown in the labels. This does not seem to affect the simulation results.
- In the tutorial, several bond and angle parameters are modified, and some bonded interactions are removed. Is this step always necessary, or is it only required when reproducing a parameterized model from a specific publication? If these bonded parameters are removed, are the corresponding interactions simply omitted from the force field, or are they treated as rigid constraints?
- I found polarizable Martini water model here: https://r1132100503382-eu1-3dswym.3dexperience.3ds.com/community/swym:prd:R1132100503382:community:PicGX_96TjmPwe9tdYLC4w?content=swym:prd:R1132100503382:qnaquestion:UKpaKSyUQCWXSAfHGmrAOAIs this still compatible with Martini 3?
Thank you so much for the insights and suggestions.
Hi Aaron,
Some good questions there. Let me take on your first question about the strategy or rules for mapping. In general, the Martini forcefields have used a 4:1 mapping for heavy atoms to beads. This was the 'ideal' but in practice the typical mappings would vary from 3:1 to 5:1. Then to model cholesterol and other rings like benzene, an S variant was defined with a 2:1 mapping. This gave rise to bead types like SP1 and SC1 (see [1], fig 1). A good discussion of mapping strategy is given in section 3.4, step I [1]:
Bear in mind that there are three generations of the Martini forcefield and the mapping strategies have become increasingly higher resolution (and more complex). Ref [1] is Martini 2. In Martini 3, three different bead sizes were introduced labeled R (regular), S (small) and T (tiny) [2].
But the first step is to check whether your molecule has already been mapped. If so, you can reuse the same mapping. For Martini 3, you can find the existing molecules in a library [3].
[1] Martini 2: J. Phys. Chem. B, Vol. 111, No. 27, 2007 7813
[2] Souza, P.C.T. et al., “Martini 3: a general purpose forcefield for coarse-grained molecular dynamics”, Nature Methods volume 18, pages 382–388 (2021).
[3] Martini 3 Lipidome: https://cgmartini.nl/docs/downloads/force-field-parameters/martini3/lipidome.html
Hi Aaron,
Here is a stab at your 2nd question:
Now the forcefield generator script specifically applies to Martini 3. Notice that there are two out-of-the-box forcefields available in Mesocite called "MS Martini" and "MS Martini 3". These are our versions of the 1st and 3rd generations of Martini. But Martini 3 is quite complex with a lot of bead types. The purpose of the script is to allow you to generate a Martini 3 forcefield file that you can then customize to your purposes. Instead of importing all the types into the .off file, only the ones you need are there, making it easier to work with.
In the case of this particular application: a DLPC bilayer, you probably could have achieved similar results using MS Martini or MS Martini 3, but the point is to teach people how to go beyond that in other situations. In this application we learned how to substitute better angle and bond parameters for the generic ones that would have been used in MS Martini 1 or 3.
Regarding your third point:
The interaction parameters are only determined by the ForcefieldType. There is also a BeadTypeName and Name property on each bead. There is also a read-only Mass property that is determined by the BeadTypeName assigned.
For question 4:
See also my comments on question 2. The scripts will help automate Martini 3 setup in cases where you want to go beyond the generic valence parameters. If the bonded interactions are removed (you can try it), you will still get bond energies as reported in the output file. That is because it falls back to the generic X-X bond parameters. Fallbacks are determined in the Equivalences tab of the forcefield, which is a little more difficult to understand.
Hello Jason, thank you for your detailed explanation! I will read the referenced paper in the comment and try to set up some simple systems first.
