I noted with interest that with the release of Materials Studio 7, CASTEP could now calculate excited state effects. I was surprised, however, about the lack of documentation regarding the implementation. Is it fair to assume that the Casida approach is implemented and that one needs a discrete level system (e.g. finite extent)? Assuming this to be true, I tried a small cluster of GeTe from a carefully converged ground state structure, but found that the TDDFT calculation did not converge in the 50 default interations allowed. It would appear that the front end is rather limited in its options which leads me to my question. Where can I find an exaustive list of the keywords for the cell and parameter CASTEP input files regarding a TDDFT calculation? Is there any more extensive documentation planned or even better already available? If such documentation is available already, I apologize for not finding it myself and would appreciate hearing of appropriate links or examples.
Best wishes,
Paul Fons
Dear Paul,
This is the first release of CASTEP TDDFT, so thank you for your interest. We are keen to hear your feedback.
The implementation follows the approach of Joerg Hutter
(Hutter, Jürg Jürg, I Introduction, and Van Caillie. “Excited State Nuclear Forces from the Tamm–Dancoff Approximation to Time-Dependent Density Functional Theory Within the Plane Wave Basis Set Framework.” The Journal of Chemical Physics 118, no. 9 (2003): 3928. doi:10.1063/1.1540109.) rather than Cassida. It is currently restricted to the Tamm-Dancoff approximation, to vertical excitations and to use a single k-point-only description of the ground state (which need not be the Gamma point). So it should in principle be applicable to your GeTe cluster.
The list of keywords can be obtained by running the server executable standalone with the "--help" option (-help before 7.0)
castepexe --help search TDDFT
Help information on CELL keywords:
Help information on PARAMETERS keywords:
TDDFT_NUM_STATES number of TDDFT states
TDDFT_SELECTED_STATE TDDFT state to use in geometry/MD
TDDFT_EIGENVALUE_TOL state convergence tolerance
TDDFT_CONVERGENCE_WIN convergence tolerance window in TDDFT calc
TDDFT_MAX_ITER maximum number of iterations in TDDFT calculation
TDDFT_NEXTRA_STATES number of extra TDDFT states
TDDFT_XC_FUNCTIONAL TDDFT exchange correlation kernel
TDDFT_METHOD Method used to approach TDDFT
TDDFT_EIGENVALUE_METHOD TDDFT matrix solution method
TDDFT_APPROXIMATION select Tamm-Dancoff approximation in TDDFT
castepexe --help TDDFT_MAX_ITER
None found
TDDFT_MAX_ITER *! maximum number of iterations in TDDFT calculation!*
Type: Integer Level: Intermediate
The maximum number of iterations to take during a TDDFT calculation Allowed values: (any integer) > TDDFT_CONVERGENCE_WIN Default value : 50 for Davidson solver, 200 for CG solver
There are some presentations online which can easily be found using Google, eg
http://www.hector.ac.uk/cse/distributedcse/reports/castep02/
http://www.hector.ac.uk/cse/distributedcse/reports/castep03/
www.tcm.phy.cam.ac.uk/~mdt26/esdg_slides/jochym_oct13.pdf
I hope these prove useful.
Keith Refson
