Error while importing a .xsd file
I could not import .xsd file. I get the below message.
The document could not be imported:
Failed to import document from C:\\Documents and Settings\\Administrator\\Desktop\\Cell_3.xsd.
-Unable to process XSD content -Unable to parse XSD as a valid XML -Expected comment or processing instruction at a line 32531, column 2.
And also when I tried to run my job in clusters, I got license error as:
Error: #-16 (LP 7.6.3)
Cannot read data from license server system.
The license server system appears to be running, but is not responding. If this persists, notify the System Administrator. (The license server manager (lmngrd) and vendor daemon processes should be terminated and restarted.)
I think that when I run script, it also could not import again, so could not run job and gives the errror message.
I think that these two error messages are related with each other.
I will be very pleased if anyone knows how I can solve this problem. Thanks a lot.
Sincerely,
