I am new to Materials Studio and really do not know what to follow for asking a proper question and what details I should provide to get a proper answer.
I have installed a fresh Ubunut20.04 on a i5 (4GB RAM) PC and have extracted the tar file of materials studio 2018 and then followed the installation steps given in the installation manual.
I am getting below error
dio 2018
The location where Materials Studio will be installed is
[/home/kcbhamu/BIOVIA] /home/kcbhamu/MS2018
The BIOVIA License Pack is required in order to run Materials Studio 2018.
Please enter the location of a License Pack installation, or an empty directory
into which the License Pack will be installed.
[/home/kcbhamu/MS2018]
/home/kcbhamu/MS2018 does not appear to contain a supported License Pack installation. Would you like to
install it to that location? [Y/n]
[Y] y
Would you like to specify an alternative Gateway port number (default is 18888)
[N] y
Please enter the port number
[18888] 19178
Do you wish to start the Gateway service after installation? Answer no here if
you wish to configure security settings before starting. (Y/n)
[Y] y
Running LicensePack installation...
Verifying archive integrity... All good.
Uncompressing License Pack and extracting files, please wait.....................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
./install_lp.sh: 73: Syntax error: redirection unexpected
WARNING: You have either chosen to cancel your installation, or an error has occurred.
Please Verify your usage is correct:
Usage: lp_setup [-silent] [-console] [-P licensepack.installLocation=
-silent - installs the product in silent mode.
-console - installs the product in console mode.
-P licensepack.installLocation - allows the user to specify the location to install License Pack.
-V PRODUCT_LP_FILE - write License Pack Install directory to file.
Port@HostName - specify the port@hostname of the License Pack server.
-C - to run License Pack Compatibility Mode on silent.
If usage is correct please refer to FAQ section of the LicensePack documentation or contact BIOVIA Support.
The LicensePack documentation index is called LicensePack.html and is located on the CD.
Return Code: 2
LicensePack installation failed
Could someone please tell me how to install MS2018 on Ubuntu?
Thank you very much
Regards
Bhamu
