Error Code 135 occured when submitting a forcite job ?
Hi all, I'm new to MS. I met a problem when submitting a forcite job to a remote linux MS gateway.
The job contained a .trj file with size 900+ mega bytes. The submition proceeded for several minitues then failed with error code 135.
It reported as follows:
Error communicating with server gateway. Code 135. Description: Failure in terminating gateway request.
Job failed during launch process, no results generated, no results downloaded, and project results folder has been removed.
The remote linux gateway setting of forcite module is : Timeout = 90, MinimumPollingInterval=2000.
Is it the problem of mine or of the remote gateway settings? Anyone can help?  Thanks in advance!
