Dear MatStudio Community,
I am trying to run a monte carlo simulation in the Gibbs Ensemble. I should be able to do this with the Equilibria Module. The problem I am having is that I don't want to use the NERD forcefield, but instead a user-defined forcefield. I have created the necessary *.frc, *_template, and *.rlb files for the forcefield and I can use these files to run MD simulations in Discover, but I suppress the automatic typing in the Discover simulation set-up.
If I try to run the Gibbs Ensemble MC, I get an atom-typing/ charge assignment error using my user-defined forcefield file (it fails to assign ff-type/ charge to all of the atoms in the first simulation box; I presume that this prevents it from trying in the second box). The atoms in the initial models have already been assigned the correct FF types. Is there a way to turn-off automatic FF typing in the Equilibria module? I have been unable to find that toggle switch in Equilibria.
Your insights and suggestions are appreciated.
Thank you,
Aric
