Doubts about the inconsistency of text formatting between single structure file and transition path output file
Dear Materials Studio Engineer,
        When a single crystal structure file is saved as a car file, the elements and serial numbers are output (as in the first column of Fig. 1), whereas when a transition state path file is saved as an arc file, no serial numbers are generated (as in the first column of Fig. 2). How can I do this so that the transition path file is also output as shown in Figure 1?
        Thank you for your kind help, looking forward reply:)
