DMol3 Optimization Problem: How to solve?
Dear Community members,
I am optimizing an Organic simple-structure in 3D atomistic file. During Optimization calculation gives the following error. Can anybody suggest how to solve it? Probably it is a very silly mistake, however, I am unable to resolve it after several trials.
The message was:
Publications of specific relevance to this calculation:
Density functional:
PBE functional: Perdew Burke Ernzerhof: Phys. Rev. Lett. 77, 3865 (1996)
Spin unrestricted calculation
The Generation and Use of Delocalized Internal Coordinates in Geometry optimization;
Baker Kessi Delley: J. Chem. Phys., 105, 192 (1996)
Andzelm Fitzgerald King-Smith: Chem. Phys. Lett., 335, 321 (2001)
Fractional occupations and density functional energies and forces; Weinert Davenport: Phys. Rev. B 45, 13709 (1992)
Fractional occupations, iterative stability:
Delley in; Modern Density Functional Theory vol 2 pg 221 ff (1995),
 Elsevier, Seminario Politzer eds.
Parallel eigenvalue solution:
Parallel solution of partial symmetric eigenvalue problems from electronic structure calculations:
Auckenthaler, Blum, Bungartz, et al.: Parallel Computing 37, 783 (2011)
Warning: SYMDEC file generation reset to off
Calculation is Spin_unrestricted
Warning: no SYM file, no symmetry used in vibrational analysis
Warning: at least C1 SYM file should be there for optgeom
Evaluating last optimization step:
Predicted energy change = -0.112E-08 Ha
   Actual energy change =  0.838E-05 Ha
    Rejection threshold =  0.200E-05 Ha
Warning: Energy went up too far during optimization.
         Dismissing last step and starting in new search direction.
*** OPTIMIZATION USES DELOCALIZED INTERNALS ***
The preliminary size of active space is :       9
There are :            9  degrees of freedom
There are likely:     10  primitive internals
DMol3.pl message: DMol3 job finished in 0 hr 0 min 45 sec.
Answers 2
TG
TG 2025-07-21
Dear Keshab,
Could you attach the geometry you are attempting to optimize to the post?
I wouldn't be surprised that such an error message arises because for example the structure is duplicated exactly on the same coordinates (or some atoms of it are duplicated).
Thanks in advance,
Best regards,
Théophile
CM
CM 2025-07-22
I would try a smaller SCF convergence threshold but without getting the complete failed run and the .xsd file it is hard to say what is doing wrong.
