Dmol3, optimization, materials studio, adsorption
Dear users,
I am working on computational studies involving the adsorption of organic molecules on metal surfaces (such as iron and zinc). I am using Materials Studio with the DMol3 module for my calculations.
As I am still at the beginner stage in this field, I would greatly appreciate your guidance regarding the appropriate selection of the k-point mesh for my system. Specifically, I am working with a surface model of size 8×8 consisting of five atomic layers, and I would like to ensure that my calculations are both accurate and computationally efficient.
Could you kindly advise me on how to choose a suitable k-point grid for such a system? Additionally, I would be grateful for any recommendations or best practices you might suggest for achieving reliable adsorption results using DMol3.
I would also like to ask whether it is necessary to perform geometry optimization for the unit cell before constructing the surface model. If so, what k-point mesh would you recommend for the unit cell optimization step?
Edited
When performing optimization, is there a single k-point for both the unit cell and the surface? If I want to compare more than one surface, for example, Fe (0, 1, 1) and Zn (0, 0, 2), should the k-point mesh be constant? And how should it be chosen? What are the steps of convergence test?
Answers 3
TM
TM 2026-03-26
In Materials Studio, DMol3 Calculation dialog automatically suggests recommended parameters including k-point mesh parameters. You can set Monkhorst-Pack grid parameters a, b, and c in DMol3 Electronic Options dialog > k-points tab.
Yes, it is necessary to perform geometry optimization for the unit cell before constructing the surface model. Otherwise, the (residual) stress in 3-dimensinal crystal will not be released. Optimize each component individually, then combine them to create the structure of interest as follows,
    1. Optimize an organic molecule in vacuum,
    2. Optimize atoms' positions and cell parameters of 3-dimensional crystal,
    3. Cleave surface and optimize atoms' positions of 3-dimensional slab,
    4. Locate the molecule onto the slab and optimize atoms' positions.
JL
JL 2026-03-30
Yes, it’s essential to ensure consistent program settings, in particular when you are to compare between different surface orientations and across projects.
Most importantly, in case you hadn’t noticed, there exists a vast field in computational surface chemistry studies from the early 90s, even specific to using the DMol3 tools.  Among all resources, I’d strongly recommend to take a look at the BIOVIA Reference Center, search for relevant subject matters, and see how fellow scientists are approaching similar researches.
Hope it helps,
Jian-jie
CM
CM 2026-03-31
I do not know if this is the most recent version of this (link below). In principle, you have to do convergence testing of the parameters of a CASTEP run and this also applies to DMol3:
* different surface terminations
* Plane wave cutoff. (not n DMol3)
* k-point spacing
* Vacuum slab width so that only one surface is seen by the adsorbed molecules.
* Number of layers to come close to bulk behavior.
To be able to compare things one has to use the same k-point spacing under CASTEP_Calculation > Electronic > More > k-points > Separation.
After that switch to Custom grid parameters and make sure that  there is only one k-point along the direction of the vacuum slab.
This does not yet take into account developments in CASTEP since then:
dispersion correction, modern functionals, on-the-fly-generated pseudo potentials, ....
@R&D: feel free to add further things. I will try to update this post.
