DMol3 Geometry optimization, SCF iteration not converged.
I am working on transition metal cluster. I want to do geometry optimization, but the problem is during freq calculations. During the geometry optimization, when i do by turing off the symmetry, it does not go well. I mean scf does not converged. But when i turn on the symmetry, it does, and i am also able to get vibrational frequency in the default smearing, charge and spin mixing factor. So my idea here is,
1) At first i will do geometry optimization either turning symmetry off, or by using harris function from LDA.
2) when a get the optimized structure, i would like to run it with GGA using symmetry on.
By doing this i am able to get some of my simulation done. And since, i am working on cluster, i do not know the symmetry.
What do you think with this technique of geomtery optimization.
I have also tried using DIIS_Restart off, no luck in some of the simulations.
As far as i read the tutorial, it says that using harris functional, we get good accuray in the geometry of the input file, but the energy value and difference of the energy can't be trusted, e.g. binding energy of gas on these cluster.
What do you all think on this?
Answers 2
SG
SG 2015-01-13
Dear Carsten,
Thank you for your reply.
Yes i do use Use_DIIS_Restart off. At first i run the geometry optimization simulation without freq analysis. After my simulation is done, I run for freq analysis using DIIS off command. I have Attached the folder.
The problem is scf convergence either before freq analysis or during freq analysis.
In order to make sure with the geometry of the system, i also do forcite before running Dmol3.
Moreover, the thermal smearing value i want to use is default value not 0.01. I tried to run geometry optimization for several times with default smearing value, i did not succeed. Therefore, the input file has 0.01 value for thermal smearing.
comment imagecomment image
CM
CM 2015-01-13
Personally, I am not sure if Harris really can be of help here. If you are under proper maintenance please contact support@accelrys.com.
Could you please zip and post the a complete run. You can remove all *.tp* files from the *.zip file.
Remarks:
Please do the geometry optimization first and then then frequency run in a separate run.
Do you really use DIIS_Restart off?
It should be
