Hi everybody,
When I do a optimization of a system. Dmol field and error was " number of integration points exceeds limit". I check the intenet and found the way to solve in "
http://www.ifm.liu.se/compchem/msi/doc/life/insight2K/dmol/D_Utilities.html". It says to increase the ratio-index parameter to 30
But I did not found where to change the number of the ratio index parameters. What should I do ? Hoping for your reply.
