Differnt results of IFT with different no of molecules
Hi Everyone
I am working on calculating interfacial tension using DPD. Initially i used a box size of 15-6-6 and invesitigated  many parameters. Now i got a high speed computer and i want to increase the no of molecules. Now i used box of 30-12-12. But now i am not getting the same result even after increasing no of steps to i million. Can you please comment how can i get same results and why we are getting differnt results. Everything remaining like bead lenght properties interaction  is same
Thanks
Answers 1
RA
RA 2015-05-08
Hi Shiz,
I suspect this is a finite-size effect. Velázquez et al [1] calculated the interfacial tension over a range of system sizes and found a systematic drop in tension at constant volume (Lx* is the short side of the box, i.e. 6 and 12 in your case):
They also found that when fixing the pressure in the elongated direction (Pzz) rather than the length, the effect largely disappears. This ensemble is not available in Materials Studio, although you could measure the stress and adjust the length accordingly.
Regards,
Reinier
[1] Velázquez ME, Gama-Goicochea A, González-Melchor M, Neria M, Alejandre J, Finite-size effects in dissipative particle dynamics simulations, J. Chem. Phys. 124(8):084104 (2006)
comment imagecomment imagecomment imagecomment image
