I've already asked this in the Pipeline Pilot forum but I thought I'd try my luck here.
My COSMOconf and TURBOMOLE are now installed on a Windows server. How do run COSMOconf from the command line on multiple cores? The linux syntax was np=32. I'm assumng I can edit the below .bat file with something like set np=32
Can anyone help?
Thanks
echo off
set TURBODIR=E:\\Program Files\\BIOVIA\\PPS\\apps\\scitegic\\solchembin\\bin\\TURBOMOLE
set TURBOWINDIR=E:\\Program Files\\BIOVIA\\PPS\\apps\\scitegic\\solchembin\\bin\\TURBOMOLE
set PATH=E:\\Program Files\\BIOVIA\\PPS\\apps\\scitegic\\solchembin\\bin\\TURBOMOLE\\scripts;E:\\Program Files\\BIOVIA\\PPS\\apps\\scitegic\\solchembin\\bin\\TURBOMOLE\\bin\\winnt;%PATH%
set TM_LICENSE=E:\\Program Files\\BIOVIA\\PPS\\apps\\scitegic\\solchembin\\bin\\licensefiles\\license.txt
set MS_INSTALL_ROOT=E:\\Program Files\\BIOVIA\\PPS\\apps\\scitegic\\materials\\server
set PATH=%MS_INSTALL_ROOT%\\share\\bin;%PATH%
IF "%CommonProgramFiles(x86)%" == "" GOTO WIN32
set ACCELRYS_LP_DLL=%CommonProgramFiles(x86)%\\BIOVIA\\LicensePack
GOTO CONTINUE
:WIN32
set ACCELRYS_LP_DLL=%CommonProgramFiles%\\BIOVIA\\LicensePack
:CONTINUE
set PATH=%ACCELRYS_LP_DLL%;%PATH%
cd E:\\Program Files\\BIOVIA\\PPS\\web\\jobs\\userX\\ppcD39C5-5042-4C61-BDE1-D1C236F387C9\\temp\\CMcalc\\cpu_test
"E:\\Program Files\\BIOVIA\\PPS\\apps\\scitegic\\solchembin\\bin\\COSMOconf\\cosmoconf_job_wrap.exe" jobdefinition.xml
