Component composition with DMol3
I use DMol3 to run DFT calculations remotely on a supercomputer.
Currently I am investigating Cd/Zn Alloy system.  On the Materials Studio Visualizer, I managed to create the composition Cd 95%/Zn 5%, however, nothing in the .car or ,input appears to consider this composition and only Cd appears in the .car file.  Any idea how can I include this in the calculations?  Is there any other files need to be uploaded rather than the .car and .input files?
Answers 6
BM
BM 2015-01-07
Hi
If you create a model 3d document in Materials Studio visualizer that contains a mixture of elements and then export that as a .car/.mdf file pair then the same mixture should be in that file.
If you are still having problems with this can you post as a .zip file the .xsd file and the .car/.mdf file pair.
Regards
Simon
IS
IS 2015-01-08
Thanks Simon.  The .car/.mdf files were created by clicking on "Files" button in "DMol3 Calculations" tool box, but I did not see the composition that I wanted there.  I created the files using "Export" tab as you have suggested, but again the composition is not there.  I attached the files of both trials to the original discussion.  Your help is really appreciated.
Thanks again
FH
FH 2015-01-08
Computing alloys with partial occupancy of a site involves an approximation that is not available in DMol3. The only QM module in Materials Studio that supports this type of calculation is CASTEP. If you want to model your alloy with DMol3, you will have to set up explicit unit cells that have the correct composition and then potentially sample several different unit cells.
As of Materials Studio 8.0, setting up these unit cells is straight-forward in scripting using the StatisticalDisorder tool.
Best,
Felix
BM
BM 2015-01-08
Hi
I took a look at the .xsd file and that shows that you have two "atoms":
  1. Components="Cd,0.95%;Zn,0.05%"
  2. Components="Te"
The .xsd file contain one real atom with element Te and another that is a combination of two Cd & Zn (which I have not seen before).
In the .car file there is only Cd and Te and I suspect that the .car/.mdf file can't cope with it and can only handle real atoms i.e. those made of only one element type. The .xsd file format is native (specific) to MS and really represents a dump of the model 3d document object model so it will at times contain information that file formats, other than .xsd/.xtd can't support. I would hope that the documentation would specify that information is lost or the User Interface warn users when information is lost when exporting to none native file formats!
In other words I think you are trying to do something that is not supported.
Regards
Simon
[PS Felix posted the answer below!]
IS
IS 2015-01-08
Thanks Simon.
IS
IS 2015-01-08
Thanks Felix.
